Enterprise Architect => General Board => Topic started by: Mauricio Moya (Arquesoft) on May 22, 2024, 07:20:04 am
In earlier versions of Enterprise Architect (I don't remember exactly which one, but it was over 2 years ago), when locks were used on elements and you wanted to create a connector between two elements, one of which was locked for the user and the other was not, it was only possible to do so in one direction (I don't remember), meaning the connector could be created depending on whether the source of the relationship was not locked for the user (or the destination, I don't remember).
In the current version (16.1), I notice that connectors can be created between locked elements, even if both are locked for the user (red lock). Is this the case? Can someone confirm this behavior? Or is this a new bug? Since when has it worked this way?
Settings > Security > Administer > Apply Locks to Connectors
Prior to the introduction of that setting only version control locking applied.
If you're seeing a difference in 16.1 my guess would be it's a new model that doesn't have that setting applied.
With this option, I can't create a relation between locked elements, but if I need to create a relation between a locked element and an unlock element, it only works if the source is on the unlocked element. Is it because the connector is created on the source element?
Yes
Ok. A workaround is to disable the Lock Connectors option and create a model based addin to prevent creating relations only between locked elements.
