Enterprise Architect => Uml Process => Topic started by: chesterw on June 13, 2024, 10:40:01 pm
Hello EA Sparx Community,
I am currently working on a project in Enterprise Architect and utilizing MDG Technologies. I need to ensure that some of the property fields for specific diagram elements are mandatory or required.
Could anyone guide me on how to configure these settings within MDGs? Specifically, I am looking for a way to enforce that certain properties must be filled out by users when they are creating or modifying elements.
For example, if I am creating a activity, the name of the activity must be filled out or you cannot create the activity.
Thank you in advance for your assistance!
Best regards,
Chester
You would probably need in an add-in to check and eventually croak when a new element is created.
(there is no need to post the same question in two forums)
Hi q, thank you for the reply! Could you elaborate a bit on how the add in could work?
Sort of ... You subscribe to the new-element-creation event and when your routine is called you simply check the contents and eventually croak. Geert has a nice description on "how to create an add-in in 10 minutes". (It takes a bit more than 10 minutes but within a day even I was able - with no Cxx and Windoze background.)
