Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Thomas Arnbjerg on August 16, 2024, 10:16:45 pm
I've created a profile with a stake holder requirement stereotype. For some reason this is confused with the BABOK::stakeholder requirement. Is there a way to avoid this?
I always add a prefix to my stereotypes to ensure they are unique.
So in your case that could be myProfile_stakeholder
Another tip is to always use the fully qualified stereotype where possible. (e.g. scripts, csv import/export etc..)
You can also disable the MDG's you are not using with a perspective set. You can make your own perspective set with only those MDG's you are actually using and set that as the default for you model.
The MDG's that are not selected will no longer be visible for the users.
Thanks for the response. Disabling the technologies under 'Settings'->'Options'->'MDG Technologies' fixes the issue.
That is no longer the preferred way, but I guess that will would as well.
