Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: vrieg on October 31, 2024, 05:58:57 am
I added UML Types e.g. taggedvalues to an MDG .
However within the project I dont see them. How can I access those tagged values from am MDG that is included as xml reference in EA16?
I've included UML Types in an MDG however, it was to ensure that tagged values were typed on the defined stereotypes. For example a couple of date Tagged Values on a stereotype like Installed Date [Date], Retired Date [Date] on an Application [Stereotype].
Not sure if just defining the UML Types alone and putting them in an MDG works actually. I can't see them in my model which uses the MDG I created either but they work for the tagged values.
You might want to try another way such as an export/import of reference data found under Settings tab>Transfer>Export Reference Data...
yes this is what i did now I added them to the mdg in term of xml document and had to ensure to import the uml types again to the projects.
I need this to use sparx importer/exporter to office and to enable transferring information from/to stereotypes
