Enterprise Architect => General Board => Topic started by: Papa_Bear on January 16, 2025, 07:04:06 am
I have a very simple table of data - Item_name_short, Item_name_long, System, Org, and Type.
It doesn't get much simpler!
I'm using this as a simple test to try pulling this structure in from external (Excel, CSV, I don't care... Access import won't work either...).
If you want some info on what I've tried:
I tried creating a DataModel, but the "Tables" entry wouldn't let me create a new table.
I then discovered I must use the "Database Builder" - so did that - and created a table, with the fields. (The new table then showed up under the DataModel "Tables" folder - where it would not let me create the table???)
I then realized that I really don't want to start by telling EA about this, I want to import all of this info from a file.
So I abandoned that and tried to find help on importing. Interestingly (based on a tutorial video I found), to do an import - one must go to the 'Publish' option. I never would have found that without the demo video I found.
If you only want to know my question:
Can someone explain exactly how to import data, with my own custom fields, into EA - and have it do its magic on representing the table?
I thought I could point it at an Excel file (properly formatted) and it would figure this out. Apparently not.
Apparently, it involves creating/exporting an import spec - which is cool, but that import spec does NOT allow me to specify which of MY fields to bring in (????) - so I'm lost immediately. It seems there is some other .csv file also generated - which then is used to perform the import?
I am totally lost.
I would very much appreciate a link to some kind of document or tutorial that actually explains how to do this - and what is in each file that is needed etc.
thanks!
Importing tables is not as simple as you might thing.
CSV import only covers elements (table) not attributes (columns)
You can use
- The Office MDG
- My Excel importer https://bellekens.com/product/ea-excel-import-export/ (https://bellekens.com/product/ea-excel-import-export/)
- A custom written script
OK - thanks for the response/info!!
