!INC Wrappers.Include
!INC Local Scripts.EAConstants-VBScript
' Script Name: MergeDuplicatesMain
' Author: Geert Bellekens
' Purpose: Merge duplicated elements into one
' Date: 2022-05-13
'name of the output tab
const outPutName = "Merge Duplicates"
sub Merge
'exit if not on element
if Repository.GetContextItemType() <> otElement then
msgbox "Script only works on elements. Please select an element before executing this script"
exit sub
end if
'get selected element
dim selectedElement as EA.Element
set selectedElement = Repository.GetContextObject()
'Let the user select the original object
msgbox "Please select the original object"
dim originalElement as EA.Element
set originalElement = getUserSelectedElement(selectedElement)
'check if user selected
if originalElement is nothing then
msgbox "User cancelled script"
exit sub
end if
'check if user did not select the same element twice
if originalElement.ElementID = selectedElement.ElementID then
msgbox "Please select a different element"
exit sub
end if
'check if the name and type of the element are the same
if originalElement.Name <> selectedElement.Name _
or originalElement.Type <> selectedElement.Type then
msgbox "Please select an element with the same name and type"
exit sub
end if
'Ask user if he is sure
dim response
response = msgbox("Merge '" & selectedElement.FQName & "' to '" & originalElement.FQName & "'?" , vbYesNo+vbQuestion, "Merge Elements?")
if response <> vbYes then
'user did not confirm
exit sub
end if
'create output tab
Repository.CreateOutputTab outPutName
Repository.ClearOutput outPutName
Repository.EnsureOutputVisible outPutName
'set timestamp
Repository.WriteOutput outPutName, now() & " Starting merge of '" & selectedElement.Name & "'", selectedElement.ElementID
'start with diagram usages
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Diagrams for '" & selectedElement.Name & "'", selectedElement.ElementID
fixDiagrams selectedElement, originalElement
'then process relations
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Relations for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeRelations selectedElement, originalElement
'then process instances
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Instances for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeInstances selectedElement, originalElement
'process nested elements
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Nested Elements for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeNestedElements selectedElement, originalElement
'process nested diagrams
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Nested Diagrams for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeNestedDiagrams selectedElement, originalElement
'process attributes using this entity as type
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Attributes for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeUsingAttributes selectedElement, originalElement
'process parameters using this entity as type
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Parameters for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeUsingParameters selectedElement, originalElement
'process operations using this enity as return type
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Operations for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeUsingOperations selectedElement, originalElement
'set timestamp
Repository.WriteOutput outPutName, now() & " Fixing Conveying Informationflows for '" & selectedElement.Name & "'", selectedElement.ElementID
mergeConveyingInformationFlows selectedElement, originalElement
'refresh
'Repository.RefreshModelView(0)
response = msgbox("Delete '" & selectedElement.FQName & "'?" , vbYesNo+vbQuestion, "Delete Element?")
if response = vbYes then
'user confirmed
deleteElement selectedElement
end if
'set timestamp
Repository.WriteOutput outPutName, now() & " Finished merge of '" & selectedElement.Name & "'", selectedElement.ElementID
end sub
function deleteElement(element)
dim owner as EA.Element
if element.ParentID > 0 then
set owner = Repository.GetElementByID(element.ParentID)
else
set owner = Repository.GetPackageByID(element.PackageID)
end if
dim i
for i = 0 to owner.Elements.Count -1
dim temp
set temp = owner.Elements(i)
if temp.ElementID = element.ElementID then
owner.Elements.DeleteAt i, false
exit function
end if
next
end function
function mergeConveyingInformationFlows(duplicateElement, originalElement)
'find operations that have the element as type of a parameter (or returntype)
dim sqlUpdate
sqlUpdate = "update x set x.Description = replace(x.Description, '" & duplicateElement.ElementGUID & "', '" & originalElement.ElementGUID & "') " & vbNewLine & _
" from t_xref x " & vbNewLine & _
" where x.Behavior = 'conveyed' " & vbNewLine & _
" and x.Description like '%" & duplicateElement.ElementGUID & "%' "
'execute update statement
Repository.Execute sqlUpdate
end function
function mergeUsingOperations(duplicateElement, originalElement)
dim sqlGetOperations
sqlGetOperations = "select op.OperationID from t_operation op where op.Classifier = " & duplicateElement.ElementID
dim operations
set operations = getOperationsFromQuery(sqlGetOperations)
'loop operations
dim operation as EA.Method
for each operation in operations
operation.ClassifierID = originalElement.ElementID
operation.ReturnType = originalElement.Name
operation.Update
next
end function
function mergeUsingParameters(duplicateElement, originalElement)
sqlGetOperations = "select distinct opr.OperationID from t_operationparams opr where opr.Classifier = " & duplicateElement.ElementID
dim operations
'loop operations
'loop parameters
dim parameter as EA.Parameter
for each parameter in operation.Parameters
if parameter.ClassifierID = CStr(duplicateElement.ElementID) then 'need to convert to string because parameter.ClassifierID is a string and not a long
parameter.ClassifierID = originalElement.ElementID
parameter.Type = originalElement.Name
parameter.Update
end if
next
next
end function
function mergeUsingAttributes(duplicateElement, originalElement)
'find using attributes
dim sqlGetAttributes
sqlGetAttributes = "select a.ID from t_attribute a where a.Classifier = " & duplicateElement.ElementID
dim attributes
set attributes = getattributesFromQuery(sqlGetAttributes)
'loop attributes
dim attribute as EA.Attribute
for each attribute in attributes
attribute.ClassifierID = originalElement.ElementID
attribute.Type = originalElement.Name
attribute.Update
next
end function
function mergeNestedDiagrams(duplicateElement, originalElement)
dim nestedDiagram as EA.Diagram
for each nestedDiagram in duplicateElement.Diagrams
nestedDiagram.ParentID = originalElement.ElementID
nestedDiagram.PackageID = originalElement.PackageID
nestedDiagram.Update
next
end function
function mergeNestedElements(duplicateElement, originalElement)
dim nestedElement as EA.Element
for each nestedElement in duplicateElement.Elements
nestedElement.ParentID = originalElement.ElementID
nestedElement.Update
next
end function
function mergeInstances(duplicateElement, originalElement)
'find all instances
dim sqlFindInstances
sqlFindInstances = "select o.Object_ID from t_object o where o.Classifier = " & duplicateElement.ElementID
dim instances
set instances = getElementsFromQuery(sqlFindInstances)
'loop instances
dim instance as EA.Element
for each instance in instances
instance.ClassifierID = originalElement.ElementID
instance.Update
next
end function
'move all relations from and to the duplicate element to the original element
function mergeRelations(duplicateElement, originalElement)
'move all relations from the dupliate element to the original element
dim relation as EA.Connector
for each relation in duplicateElement.Connectors
'move the relation to the original element
'set source
if relation.ClientID = duplicateElement.ElementID then
relation.ClientID = originalElement.ElementID
end if
'set target
if relation.SupplierID = duplicateElement.ElementID then
relation.SupplierID = originalElement.ElementID
end if
'check if such relation already exists
dim mergedDuplicate as EA.Connector
set mergedDuplicate = getMergedExistingRelation(relation, originalElement)
if not mergedDuplicate is nothing then
'save the possible changed to the merged duplicate
mergedDuplicate.Update
else
'save the changes
relation.Update
end if
next
end function
'check if a relation already exists
function getMergedExistingRelation(relation, originalElement)
'initialize at nothing
set getMergedExistingRelation = nothing
dim orgRelation as EA.Connector
for each orgRelation in originalElement.Connectors
do 'do loop to be able to skip to next
'check all parameters to skip to the next
if relation.Type <> orgRelation.Type _
or relation.ClientID <> orgRelation.ClientID _
or relation.SupplierID <> orgRelation.SupplierID _
or relation.ConnectorID = orgRelation.ConnectorID then 'if it's the same then we skip as well
exit do 'skip to next
end if
'set the name equal if empty
if relation.Name <> orgRelation.Name then
if len(orgRelation.Name) = 0 then
orgRelation.Name = relation.Name
end if
if len(relation.Name) = 0 then
relation.Name = orgRelation.Name
end if
end if
'compare name
end if
'compare source end
if not compareMergedConnectorEnd(relation.ClientEnd, orgRelation.ClientEnd) then
end if
'compare target end
if not compareMergedConnectorEnd(relation.SupplierEnd, orgRelation.SupplierEnd) then
end if
'if we get here then we have a valid merged duplicate. Return connector and exit
set getMergedExistingRelation = orgRelation
exit function
Loop While False
next
end function
function compareMergedConnectorEnd (connectorEnd, orgConnectorEnd)
'initialize false
compareMergedConnectorEnd = false
'merge cardinality
if orgConnectorEnd.Cardinality <> connectorEnd.Cardinality then
if len(orgConnectorEnd.Cardinality) = 0 then
orgConnectorEnd.Cardinality = connectorEnd.Cardinality
end if
if len(connectorEnd.Cardinality) = 0 then
connectorEnd.Cardinality = orgConnectorEnd.Cardinality
end if
end if
'compare cardinality
if getUnifiedMultiplicity(orgConnectorEnd.Cardinality) <> getUnifiedMultiplicity(connectorEnd.Cardinality) then
exit function
end if
'compare aggregationKind
if orgConnectorEnd.Aggregation <> connectorEnd.Aggregation then
exit function
end if
'merge rolename
if orgConnectorEnd.Role <> connectorEnd.Role then
if len(orgConnectorEnd.Role) = 0 then
orgConnectorEnd.Role = connectorEnd.Role
end if
if len(connectorEnd.Role) = 0 then
connectorEnd.Role = orgConnectorEnd.Role
end if
end if
'compare roleName
exit function
end if
'if we end up here they are the same
compareMergedConnectorEnd = true
end function
function getUnifiedMultiplicity(multiplicity)
getUnifiedMultiplicity = Replace(multiplicity, "0..*", "*")
getUnifiedMultiplicity = Replace(getUnifiedMultiplicity, "1..1", "1")
end function
function getUserSelectedElement(duplicateElement)
'get best match for original element
dim candidateOriginal as EA.Element
set candidateOriginal = getBestCandidateForOriginal(duplicateElement)
'build construct picker string.
dim constructpickerString
constructpickerString = "IncludedTypes=" & duplicateElement.Type
if len(duplicateElement.Stereotype) > 0 then
constructpickerString = constructpickerString & ";StereoType=" & duplicateElement.Stereotype
end if
if not candidateOriginal is nothing then
constructpickerString = constructpickerString & ";Selection=" & candidateOriginal.ElementGUID
else
constructpickerString = constructpickerString & ";Selection=" & duplicateElement.ElementGUID
end if
'invoke the construct picker
dim userSelectedElementID
userSelectedElementID = Repository.InvokeConstructPicker(constructpickerString)
if userSelectedElementID > 0 then
set getUserSelectedElement = Repository.GetElementByID(userSelectedElementID)
else
set getUserSelectedElement = nothing
end if
end function
function getBestCandidateForOriginal(duplicateElement)
'initialize at null
set getBestCandidateForOriginal = nothing
dim sqlGetData
sqlGetData = "select top(1) o.Object_ID from t_object o " & vbNewLine & _
" left join " & vbNewLine & _
" (select do.Object_ID, count(*) as NumberOfUsesOnDiagram from " & vbNewLine & _
" (select do.object_ID as Object_ID " & vbNewLine & _
" from t_diagramobjects do " & vbNewLine & _
" union all " & vbNewLine & _
" select oo.Classifier " & vbNewLine & _
" inner join t_object oo on oo.Object_ID = do.Object_ID " & vbNewLine & _
" ) do " & vbNewLine & _
" group by do.Object_ID " & vbNewLine & _
" ) do2 on do2.Object_ID = o.Object_ID " & vbNewLine & _
" where o.Name = '" & duplicateElement.Name & "' " & vbNewLine & _
" and o.Object_ID <> " & duplicateElement.ElementID & " " & vbNewLine & _
" and o.Object_Type = '" & duplicateElement.Type & "' " & vbNewLine & _
" and isnull(o.Stereotype, '') = '" & duplicateElement.Stereotype & "' " & vbNewLine & _
" order by isnull(do2.NumberOfUsesOnDiagram, 0) desc "
dim results
set results = getElementsFromQuery(sqlGetData)
if results.Count > 0 then
set getBestCandidateForOriginal = results(0)
end if
end function
'Quick and dirty via a database update
function fixDiagramsQuick(duplicateElement, originalElement)
dim sqlUpdateDiagrams
sqlUpdateDiagrams = "update t_diagramobjects set Object_ID = " & originalElement.ElementID & " where Object_ID = " & duplicateElement.ElementID
Repository.Execute sqlUpdateDiagrams
end function
function fixDiagrams(duplicateElement, originalElement)
'get diagrams where the duplicate element is shown
dim sqlGetDiagrams
sqlGetDiagrams = "select distinct do.Diagram_ID from t_diagramobjects do where do.Object_ID = " & duplicateElement.ElementID
dim diagrams
set diagrams = getDiagramsFromQuery(sqlGetDiagrams)
'loop diagrams
dim diagram as EA.Diagram
for each diagram in diagrams
'get diagramObject for the duplicate element
dim diagramObject as EA.DiagramObject
for each diagramObject in diagram.DiagramObjects
if diagramObject.ElementID = duplicateElement.ElementID then
diagramObject.ElementID = originalElement.ElementID
diagramObject.Update
'we could do an "exit for" here since in theory there should only be one diagramObject for a single element, but to be safe we don't.
end if
next
next
end function
I use a script to do the same:Do you have further guidance on how to implement the logic of merging properties and relationships of duplicate elements in this VBScript code? Thank you!
It uses some functions defined in my framework scripts that can be found here: https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/tree/master/Framework (https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/tree/master/Framework)Snow Road (https://snowroad.io/)Geert
