Pro Cloud Server / Prolaborate / WebEA => PCS General Board => Topic started by: Modesto Vega on February 15, 2025, 01:47:22 am
Is the are a way to share a WeBEA link with the browser and property view hidden?
I fear you will have to elaborate.
You can always set the properties view off by default in the global config and put it on for those that need it
Although some navigational paths are only possible via the properties window (instances)
Instances which you use for one to many travels
eg. business process end event triggers multiple events or multiple end events initiate one start event)
I want open up the repository to a group of people, limit their ability to navigate the repository by 1) directing it through a custom diagram and 2) hide the browser. In addition, to maximise screen real estate I would like to hide the properties window.
There is another group of people that should be able to use full WebEA to navigate the repository.
