Enterprise Architect => Suggestions and Requests => Topic started by: guido.albertin.infineon on June 09, 2025, 09:37:16 pm
Implement the C language support for activity diagrams, state machines and sequence diagrams?
The current distributed environment just creates the empty bodies, given that the language support is mostly empty.
Is there a chance it may be derived from the C++ template? Am I losing some important bit here?
Even if you use the Unified or Ultimate edition, you need to enable the 'Object Oriented Support' model option to generate C source codes from the behavioural diagrams such as the Activity diagrams, the Statemachine diagrams.
