Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: minna on August 07, 2014, 10:23:54 pm
Title: Type vs Subtype
Post by: minna on August 07, 2014, 10:23:54 pm
We are using UPDM 2.0 and have created an OV-2 diagram with Nodes, NodeRoles and Needlines. NodeA (parent of NodeB) contains NodeB (parent of NodeRoleA) which contains NodeRoleA. This NodeRoleA is connected with a Needline to NodeRoleB which is situated in NodeC (parent of NodeRoleB).
When running the UPDM model validation, we get a warning that states: MVR800013 - warning (NodeRoleA (NodeRole)): The object does not have a valid type (Permitted values: Node)
What is the difference between a Type and a Subtype? Where can we change the Type of NodeRoleA as suggested by this warning?
Thank you,
Minna
Title: Re: Type vs Subtype
Post by: KP on August 08, 2014, 09:10:52 am
Select NodeRoleA and press Ctrl+L
Post by: minna on August 08, 2014, 08:03:43 pm
Thanks for the reply. What am I changing when I press Ctrl+L? Type or Subtype?
What is the difference between a Type and a Subtype? When looking at the properties of a element, only Subtype is available (is NodeRole in this case), not Type.
The warning mentioned stated that we need to change the Type. Is it the same as Subtype?
Minna
Post by: qwerty on August 09, 2014, 05:26:28 am
Generally that will change the classifier.
Post by: Uffe on August 12, 2014, 07:59:09 pm
The Type is the main category of element: Class, Activity, Component, etc. The Subtype is a further subcategorization.
If you create a regular activity diagram, and create an Action, EA pops up a menu where you must select the type of Action to create. In this case, the element type is Action and the subtype is Atomic, Call Behavior, etc.
Classifier is a different thing again. It is not a categorization, but a reference to a definition. An Object normally has a Class classifier, Actions have Activity classifiers - the classifier is the reference from the instance element to the defining element.
Oh, and an element's type can be changed in the Element Properties window (not the dialog). You'll find the type displayed there, and an ellipsis button ("...") on the far right, which is normally invisible but it's there. Click that and EA opens the Select Element Type dialog.
/Uffe
