Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Mithal on November 17, 2010, 09:49:10 pm
Hi I have created a active X control using VB 6.
i have registered it and now trying to use it in my EA Addin.
i am using the follwing code:
Repository.AddWindow("Test Window", "Project1.UserControl1");
the code executes with no exception raised but the window does not get added, i even checked under the work space layout.
Does the control have to be written in .NET?
If i try to add it using:
Repository.AddTab("Test", "Project1.UserControl1");
i get the "attempted to read or arite protected memory error...."
Please can someone help with this or maybe point me to the correct Microsoft articles that shows how to create a OCX in .NET
Thanks in advance. :)
Mithal,
I think there is another topic about the addWindow somewhere.
That might be of help.
Thanks for the reply.
I have made progress with writing the .NET usercontrol and it works fine if i use it with the AddTab method available from the repository
i followed the article from this link
http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/creatingacustomview.htm
The problem i have i can add the user control using the addwindow method which works, the code is like this
m_MyControl = (Test.UserControl1)Repository.AddWindow("SYSPRO Window", "Test.UserControl1");
m_MyControl.BringToFront();
IntPtr myPtr = m_MyControl.Handle;
Now i cannot find my window, i did look under the Workspace Layouts and there is nothing. How can i trouble shoot this
I am on version 8.0 of Enterprise Architecture. Build 856.
Please Help.
Thanks in Advence.
http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/creat...
Please Help.
Thanks in Advence.
Mithal,
It should have been added to the View|Add-in Windows
Ah Thank you.
Hi Geert, hi Mithal.
I have the same problem Mithal encountered with the addTab, i get an AccessViolationException telling me that i try to access some protected memory.
Repository.AddTab("OEA Export", "Export.TestPan");
TestPan is a UserControl, and Export is the namespace of the class.
Is it the right syntax? How could i go through this problem?
Thank you very much by advance,
SJ.
Hi all,
I am having a problem about adding a add-in window to Enterprise Architect.
First of all, I am using Visual Studio 2010 and C# as the language.
I just followed the code in the following link:
but the only problem is, I don't understand how I am going to use UserControl1.
So, " UserControl1 m_MyControl;" I could not created an instance of Usercontrol to hold the pointer of the addWindow, to manipulate it.
Actually, I tried to create an ActiveX custom control object, but it seems so complicated that I tried many many times but none of them ended up with something works.
At this point I really appreciate any help that might give me a clue to where to start. I only need to create the object to hold the pointer of addWindow() and manipulate it as I need.
I even created some simple class, and registered it's .dll file with regasm.exe to the registry, but I am still not able to create an instance of the class that I registered, in my code.
I dont know if I need to add some "using" clause?
I appreciate your help.
Murat.
I've added a working example of this to my example add-in at
https://github.com/GeertBellekens/Enterprise-Architect-Add-in-Framework
Thanks a lot, I appreciate.
Nothing about addTab? If you prefer, i can create a thread on that topic. That's quite annoying, i really don't understand why it works on my boss computer (EA 7.5) and on my dev and test environment (EA 8), it crashes :(
On my dev env, i'm using Visual Studio, so if i'm not wrong there is no COM register issue liely to happen, right?
Sébastien,
I think AddTab works the same way as AddWindow.
It's not because you are using Visual Studio that you can't have COM registration issues, but a crash usually has other reasons.
I had an issue recently with EA crashing (hard) when I was trying to use the Repository object before the model was fully loaded.
You have to be especially careful with the EA_OnContextItemChanged event and the likes, since they can be launched by EA before the Repository object is ready to be used.
I found that the EA_FileOpen event is a good one to indicate a fully loaded and ready Repository object, so I used that to flip a switch on my add-in class like this
public void EA_FileOpen(EA.Repository Repository)
this.EAFullyLoaded = true;
}Then in the EA_OnContextItemChanged I do following:
public void EA_OnContextItemChanged(EA.Repository Repository, string GUID, EA.ObjectType ot)
if (this.EAFullyLoaded)
// do useful stuff
I'll try that but i'm not using the OnContextItemChanged event. The only thing we're doing is
public String EA_Connect(EA.Repository Repository)
m_RepositoryView = Repository.AddTab("OEA Browser", "OEA.TestPan") as UserControl;
return "OEASparxConnector.AddIn started";
OEA being my namespace, and TestPan a classic UserControl (that does nothing except displaying a empty text field and a button). What is odd is that this kind of code works on another computer, that's quite confusing :-/
Thank you very much Geert, that made the trick!
I moved my call to addTab only when EA detects a project is loaded and it seems to work great now!
Have a very nice day and thank you again for your help,
SJ.
Hello Guys,
Objective:
Use AddWindow to Call a User Control within the ActiveX Control window where the Addin is installed as an application
I have an issue where the AddWindow works properly from Visual Studio(Dev Mode) and not when its installed as an application.
I Use a "User Control" into the ActiveX Control which is not working as expected. Then I Also tried loading the user control inside a Windows Form it is working properly.(from an installed application).
What am i missing here Some Info. will be really helpful.
P.S:
Here i Use Wix to build the application setup.
I disabled all the other addins and it is still not working.
Thanks in advance.
This is probably because your windows form isn't registered properly for COM interop. In that case Windows will not be able to resolve the name used in AddWindow().
