Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: jan.izyk on November 06, 2015, 10:27:01 pm
Hi all,
I've got again a question about the C# API of EA.
With the command
myRepository.SQLQuery(...)
I can execute select-statements to the database.
But with this function I can't execute something like insert-into statements.
But at the scripting-interface there is the function Repository.Execute which can execute insert-into statements.
So my question is:
Is there any possibility to execute insert-into/update/... statements via the C# API like in the scripts?
Regards
Jan
As you said: Repository.Execute. This is completely undocumented and unsupported and misuse of it can damage your repository. Know what you are doing! And no question: you will not get any support for it from Sparx.
Hi querty,
thanks for your reply.
Now I have seen the Execute-function in the interface IDualRepository.
But I can't get access to this function when myRepository is from type
EA.Repository.
So do you know, how I can get access to this function?
And thanks for the hint. I know, that it is dangerous to change the database directly. But sometimes it has to be done by this way.
Hi Jan,
Just go ahead and call Repository.Execute(). The code will compile and run perfectly fine.
/Uffe
Outsch. Now I've got it.
In the autocompletition-window in Visual Studio, the function isn't seen.
I have to execute it with MY repository and not as a static function Execute of the Namespace Repository.
As a small example-function for everyone who doesn't have a clue like me
void executeSqlStatement(EA.Repository myRepository, string mySqlStatement)
myRepository.Execute(mySqlStatement);
Thanks to you q and Uffe.
