Enterprise Architect => Uml Process => Topic started by: Wassi on March 29, 2005, 03:52:40 am
I use EA for the modeling systems mixing control and data processing. To do it, I use class diagrams and state machines... I noticed that in the case of the state machines we can associate a custom diagram, activity diagram,... in a state by using "New Child Diagram". Is it possible to associate a class diagram in a state? If yes, which interpretation can we give to this process?... Another question: to what correspond a custom diagram and can it be equivalent to a class diagram?
Thank you very much
Wassi,
I don't know whether I got your question completely. Custom and other diagram types are mainly used to select different sets of icons/elements to appear on them. You will notice that the toolbox opens with different sets of elements depending on the type. I use Custom diagrams for requirements. For State diagrams there is a dedicated type you should use.
Wassi,
If you can create a Custom Diagram, you can then Change Diagram type to Class Diagram. That would not change much though - as Thomas mentioned, it will be opening different tab in toolbox. It will call iself "Class". That's all.
I don't understand what do you model like that though. State machine goes underneath a Class, not vice versa.
Cheers
Alex
