Enterprise Architect => Uml Process => Topic started by: bluemanifold on October 30, 2007, 06:12:58 am
Hi. I'm trying to create a metamodel using EA 7.0.817. When I open the package properties, the <<metamodel>> stereotype is missing from the list of available stereotypes. A <<model>> stereotype is present but is this the same thing? Any help would be appreciated. Cheers.
If you mean that you are trying to build a metamodel as part of a profile, then you are looking at the wrong stereotype.
Create a new class diagram. Now use the More Tools button at the top of the toolbox to open the Profile toolbox - or shift-right-click on the diagram and use the context menu - and add a Profile element (it looks like a package) to your diagram. The element should be a package with the «profile» stereotype already set up, and it should be set as a composite element. If you double-click it you will open a profile diagram 'within' the new profile package.
HTH, David
I guess I could do that, David. I was actually reading the help system about MOF diagrams - I want to create my metamodel as a MOF diagram and eventually export the package. That way, the package could be used by a profile model as well as within a standard class model (where it acts as a 'template'). The help system says that a <<metamodel>> stereotype is available for tagging the MOF package and yet when I go through the procedure, that particular stereotype is missing.
I'm not sure if the (small) change to the procedure has washed through to the Help you are using, but you just type the value metamodel in the Stereotype field - it's one of those stereotypes you create by using it once.
Roy
Cheers, Roy. That worked - I also found a similar topic on one of the other forums. :)
