Enterprise Architect => Uml Process => Topic started by: zapolo on August 01, 2009, 06:35:06 am
hi
can not associate to my toolbox of SOAML diagram
I can help?
(http://img31.imageshack.us/img31/967/dibujownc.jpg)
I can help?
Hi, there,
I assume that when you said "can not associate to my toolbox..", you meant the toolbox not being able to open when you open the SOAML diagram.
If this is the case, then better go to the «metaclass», check the string initial setting for attribute "toolbox". The initial should have exactly the same name as your Profile Package has.
Hope this help.
Regards, sxie
thanks for reply
the problem is the attribute of the toolbox <<metaclass>> which was not put to use the toolbox of SOAML Component
Just to be sure... Did it work once you applied the «metaclass» stereotype?
I don't understand what you ask
Hello zapolo. It is hard to know exactly what is wrong from the information you have given us. If you send your technology file (.xml) to Sparx support, someone will be able to inspect it and will be able to find out the problem. mailto: [email protected]
I have already sent
thank you very much
