Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Stealth on July 18, 2005, 12:48:10 am
Title: Customizing the UI and creating default values?
Post by: Stealth on July 18, 2005, 12:48:10 am
is it possible to customize the UI of EA?
For example i want to hide fields in the propertybox of an Element, cause they are not needed?
My second question is, is it possible to create default values in some fields, when an element is created?
Thanks a lot for your help
Stealth
Title: Re: Customizing the UI and creating default values
Post by: thomaskilian on July 23, 2005, 05:24:02 am
For 1) it is not possible to customize the GUI like you want it.
For 2) you can set a template package containing the elements you need. Each time you create an element EA will copy an existing element out of this package.
Post by: Stealth on July 24, 2005, 07:24:45 am
Hi thomaskilian,
thanks for your help. I have one more questions:
I found two ways to set default values. Using the template  package or using an Add-in Events (Post or Pre New Element). But both way are are not functional when i create an new element in the project view by the context menu.
Is it a bug?
Post by: thomaskilian on August 01, 2005, 04:15:10 am
Hm. Actually no idea. I would call this a bug and recommend to send a bug report.
Post by: Stealth on August 01, 2005, 04:47:31 am
hello thomas,
i contacted the support and it is a bug which will be fixed in one of the next builds.
