Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Paolo F Cantoni on August 20, 2005, 07:39:45 am
Title: Model Package has no Element
Post by: Paolo F Cantoni on August 20, 2005, 07:39:45 am
The Help system says (in part):
Package  A Package object corresponds to a package element in the EA Project Browser. It is accessed either through the Repository Models collection (a Model is a special form of Package) or through the Package Packages collection. Note that a Package has an Element object as an attribute - this corresponds to an EA Package element in the t_object table and is used to associate additional information (such as scenarios and constraints) with the logical package. To set additional information for a package, reference the Element object directly.
Now by Model, I think the Help system is meaning the Project Root node on the Browser.  Does that sound right?
The Model package doesn't appear to have a .Element attribute.
Can anyone else confirm that?
This would seem to be consistent with the fact that you can't open the Package Properties dialog for a Project Root, but you can for a View.
I have several repositories with multiple project roots,  I think I should be able to add standard Element properties for my project roots.  What do others think?
Cheerz,
Title: Re: Model Package has no Element
Post by: thomaskilian on August 22, 2005, 03:36:12 am
I think that the Root node should be a simple package. Its relative tree position identifies itself as a root. Maybe it could be helpfull to use the Advanced Property isRoot. Funny thing, that you can't change this Property since it's greyed out (for which reason?).
I guess that the limitation has been introduced some time ago, since I know that former versions of EA allowed elements at root level (pre 4.0?).
Post by: Paolo F Cantoni on August 22, 2005, 04:48:20 am
I think that the Root node should be a simple package. Its relative tree position identifies itself as a root. Maybe it could be helpful to use the Advanced Property isRoot. Funny thing, that you can't change this Property since it's greyed out (for which reason?).
Unfortunately, Thomas, IsRoot is not available on the Automation Interface, neither for the EA.Package nor EA.Element classes.
I can't get a clear indication how to check if a package is a Project Root, View or normal Package via the interface.
I've got something working at present, but I'm pretty sure it's by accident rather than by design... :(
Post by: thomaskilian on August 22, 2005, 06:08:12 am
... IsRoot is not available ...
That's why it's greyed out in the properties. Question to Sparx: Any reason for that?
Post by: sargasso on August 22, 2005, 04:34:27 pm
I thought a model (as in "isModel") was a stereotyped package that had nothing to do with the root package.  Think about a repository that has several "complete things" in it.  Each of these could/would be contained in a separate <<model>>package, maybe using separate root nodes, maybe not.  IOW, a repository root and a UML "model" need not be the same thing.  (I cannot get this para right - hope its understandable)
The advanced property isRoot is to do with inheritance, not project positioning.  As in "isRoot" does not/can not inherit from anything vv an "isLeaf" element cannot be a parent.
Why is the root package not a normal package?  Dunno.  Also, I cant see why not.
bruce
