Enterprise Architect => Uml Process => Topic started by: Appollo on October 12, 2012, 02:21:44 am
I have a class diagram with XSD types, and when I try to generate XSD schema (Code Engineering-> Generate XSD schema), I get the following error (in Progress text area on Generate XML schema dialog):
One or more Packages missing Fileame.
I get that message/error, even if I select "Prompt when Filename" checkbox.
Any help would be appreciated.
Thank you,
It appears like a reference issue.
It is a type of problem best solved by sending the model file to Sparxsystem.
