Enterprise Architect => Uml Process => Topic started by: Jack @ YTGI on January 28, 2013, 05:47:08 am
I'm redesigning an application I wrote a few years ago. I was working on a class diagram for one of the classes and decided to import the C# class I used in the old app as a head start. EA placed the private variable declarations in the Attributes compartment, but it imported the public properties into the Operations compartment? These are setters and getters, but I have typically saved the operations compartment for methods that have behavior. Just wondering what others thought . . .
The scope (private, protected, public etc.) make no difference: variables are equivalent to attributes and properties - to operations.
Both getter and setter can have a behaviour, so a property is rather an operation than an attribute. Using of a property seems like using of an attribute, but it's syntax sugar only.
Redesigning?? Looks more like modifying to me. IMO, redesign starts with a clean sheet of paper and some specifications, not the code you used last time!
Thanks, your response prompted more research. I believe the setters and getters should not be shown at all, unless there is a specific reason to model it.
I guess the right term is "refactor"
Sorry, I didn't feel the original post warranted a reply. The application is being scrapped and completely redesigned based on almost 80 users stories. The old app fulfills about 5 of the user stories. It was just a hack to fill a need at the time.
I was importing one class that is the object that holds an RSS listing as a short cut to typing in the 20 or so properties again. One class does not an application make, at least not in this case. Once I realized EA keeps the code from the class, I deleted it anyway and recreated it from scratch.
I'm using this project to exercise as many features of EA as possible, all the way from requirements management. I have only used EA for Use Cases, Activity Diagrams and ERDs up until now. After looking through some of the videos, I got motivated to use more of the features in the application.
Thanks for all the feedback. You guys a great!
Jack
