Enterprise Architect => Bugs and Issues => Topic started by: Dave_Bullet on April 03, 2008, 10:48:03 am
Hi there,
I've written a custom SQL search to return all objects meeting certain criteria. I include object_type and object_id in the result set so when the user clicks the search result, the object is highlighted in the project browser.
The above works for all elements except packages. Do I need to return any other columns to make package selection work within the project browser or is this a bug?
David.
David,
Remember that packages have a sort of split personality. They appear in both the t_package (for attributes related to how packages work and the project structure) and t_object (for those attributes that relate to the package as an element.
Many parts of EA treat packages differently, since they are the way in which a project is organized. You might need to deal with the the Package_ID field instead of object_id.
Try selecting the ea_guid as CLASSGUID instead of the object_id.
See http://www.sparxsystems.com.au/EAUserGuide/index.html?creating_filters.htm#SQL
Thanks David. I didn't think object_id was it then tried package_id and no difference.
Spot on Simon! the ea_guid as CLASSGUID worked a treat!. the ea
_guid is suppressed on output (even better). The help implied it was used to link an object so properties dialog can be displayed. I should have tried it anyway...
To help our community, here is the useful little SQL search for finding any duplicate objects with a stereotype of "application". Omit the search term and it will find all.
I've also found some "#ifdef" type directives you can use in your SQL query searches that allow you to code different syntaxes if using the same search against say a local EAP and central RDBMS. I'll post these in due course. Them Sparx boys have thought of everything ;)
select name, alias, note, object_type, stereotype, ea_guid as CLASSGUID
from t_object
where name + object_type in
(select name + object_type
from t_object
where stereotype = 'application'
and lcase(name) like lcase('*<Search Term>*')
group by name + object_type
having count(*) > 1)
order by t_object.name
Cheers
