Sparx Announcements => Latest News => Topic started by: sparks on January 14, 2002, 03:19:29 am
On the 14-Jan-2002
Enteprise Architect Version 3.10
Special note regarding replicated models: This version of EA will update your model files (.eap) when you open them. Do not try and update a Replica project - always update the Design Master first, then synchronize the Replicas with the Master to copy the changes to the Replica. You may also elect to create new replicas from the updated Design Master and discard the old version 2.5/3.00 Replicas.
The main features are:
features
- Ability to associate a metafile with a stereotype and override the normal appearance of an object (see Stereotype Dialog in Reference section)
- Ability to set the modified date for all elements in a model branch (from the Update Package Status dialog)
- Ability to define a new method from the Message dialog for selection in Sequence diagrams
- Modification of Sequence diagrams to include support for 'implicit returns' and focus of control - Local Setting to enable/disable
- Set relation visibility window now resizable
- Ability to set generation language directly on Code Generation dialog (drop list)
- Transition names copied to 'Action' field for old style transitions
- Added undo for AutoLayout
- Some database changes for future enhancements
- Set Element Parent option on context menu for generalizable elements (creates a generalization link to any element in model)
- Autosize Selected elements in diagram option
bugs:
- Addition of VB.Net to object language droplist (on Object Properties dialog)
- Use of '\' character in element names broke RTF generation
- Tidied up name wrapping for classes
- Fixed some import errors in C# parser caused by \" (escaped quote)
- Ensure Interfaces listed in parameter drop lists
- Modifications to sequence diagram
- Additional UI fixes and consistency checks
- Improved handling of Interfaces in VB
- Improved Import and Package statement handling in Java
