Enterprise Architect => Bugs and Issues => Topic started by: bash on May 30, 2009, 05:54:30 am
I've recently started using a registered version of EA. I built several diagrams using the trial version while awaiting the funds approval from my company. Now, when viewing each diagram in the registered software - all tagged value attributes (except flow maturity) do not hold the assigned values, and some diagrams have physically shifted.
Is this an issue with trial to registered builds or does my registered version need a reinstall?
Some long shots to try...
Make sure you removed the trial version of EA before you installed the registered version. Your models will be OK. [But just to be sure, verify that you did not store them in the EA installation directory...]
If you still have the trial version installed, before you remove it you might try exporting all the reference data from the projects involved. Perhaps importing it again, into a copy of the project, using the registered version (after you have removed the trial version and reinstalled the registered version) will help. [But I doubt it.]
