Enterprise Architect => Bugs and Issues => Topic started by: kadamowi on October 29, 2009, 03:19:23 am
I have Data Model in ERwin. This tool have posibility to export it to "Spaarx Enterprise Architect" format as a XMI file.
I exported it but I can't import it to EA :-/ (version 7.5)
I have error:
Code 0xc00ce014
Source = Line : 4; Char : 24
URL file::..... EA/UML_EA.dtd
Error Description = Element content is invalid according to the DTD/Schema
Expecting: XMI header, XMI content, ...
Have You any idea ??
Import file looks like this:
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE XMI SYSTEM "UML_EA.dtd">
<XMI xmi.version="1.1" xmlns:UML="omg.org/UML1.3">
<XMI xmi.version="1.0">
<XMI.header>
<XMI.documentation>
<XMI.exporter>Meta Integration Model Bridge (in 'OMG XMI 1.0 for UML 1.3' mode)</XMI.exporter>
<XMI.exporterVersion>6.0.3</XMI.exporterVersion>
</XMI.documentation>
<XMI.metamodel xmi.name="UML" xmi.version="1.3" />
</XMI.header>
<XMI.content>
<Model_Management.Model xmi.id="_1">
Try using 'OMG UML 1.x XMI 1.x' as the Type of export from ERWin. I've had no issues importing the resulting model into Sparx.
Stan.
Can You write me more information about that ??
Now in *.xml i have line:
<!DOCTYPE XMI SYSTEM "XMI-UML-99-10-05_xmi_1.1_uml_1.3.dtd">
and error because EA can't find file dtd
Kris
update:
I set "Print DTD Reference" to 'false' and error disappeared.
You are correct, the only change I had to make to the defaults for the option I noted above was to set the print DTD to false. Thanks for clarifying.
Stan.
