Enterprise Architect => Bugs and Issues => Topic started by: Paolo F Cantoni on April 27, 2010, 05:13:04 pm
Title: WARNING: Accidentally purging Element Features
Post by: Paolo F Cantoni on April 27, 2010, 05:13:04 pm
It's been a long-standing idiosyncrasy of EA that purging1 an element feature from the repository {Command: ElementInlineFeaturesDelete [Ctrl+Shift+Del]} occurs silently.  That is, there is NO usual warning dialog:
(?) Delete selected items from the model and all diagrams?
WARNING: This action cannot be undone.
[Yes] [No]
Presumably, and here I'm giving Sparx the benefit of the doubt, to help prevent accidental purging of the feature, a complex key combination is defined to execute the command:  [Ctrl+Shift+Del].
You have to be pretty definite to use that key combination and so EA purges the feature (attribute or operation) from the repository.
Because it takes time to set up models carefully, I have set up EA (well tried anyway) to use ONLY [Ctrl+Del] (or in this specific case [Ctrl+Shift+Del]) to purge from the repository.  The [Del] key has been relegated to only removing vertexes and arcs from diagrams.
You can imagine my shock when I found that accidentally brushing the delete key also purged the selected feature from the repository!
Further investigation revealed that just about all key combinations of the [Del] key will silently purge the feature - I noticed it purely serendipitously.
I hope this is bug (and not by design) - which needs to be fixed REAL soon...
Reported,
1See: Naming - Remove vs Delete vs Purge (http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1144834578) for a discussion on the various concepts.
Title: Re: WARNING: Accidentally purging Element Features
Post by: Paolo F Cantoni on April 28, 2010, 03:59:10 pm
Sparx have allocated the following reference number: 10045541 to this report while it is being investigated.
If you can confirm the behaviour, please send a report to Sparx indicating so.
TIA,
Post by: Geert Bellekens on April 28, 2010, 04:39:50 pm
Indeed, I just tested it on 8.0.855 and the attribute I selected in the diagram was deleted from the model without warning, just by pressing the delete key.
I'll send a bug report as well.
Post by: «Midnight» on April 28, 2010, 08:22:42 pm
Did you notice when this first appeared? Should I downgrade to the final 7.5 release until this is solved?
Post by: beginner on April 28, 2010, 09:15:43 pm
Deleting attributes from the diagram with simple DEL has ever (since editing on diagram had been introduced) been this way (just verified with 7.5). I always did put this under EAUI.
b.
Post by: Paolo F Cantoni on April 28, 2010, 10:14:33 pm
b.
I guessed as much - but then why bother putting in the complex key combination ([Ctrl+Shift+Del]) as the shortcut?
It should be fixed...
Post by: beginner on April 29, 2010, 12:26:28 am
Sure it should. Like so many other things. I guess you could achieve a masters degree in social software engineering by analyzing how Sparx have de-developed their product: EAUI - A Case Study.
b.
