Author Topic: EA Sucks?  (Read 981 times)
fararooy
EA Sucks?
« on: January 02, 2018, 10:57:26 pm »
Hi ... I am very concerned about how slow the EA tool generally is, but also much worse (and even impossible to use) depending on the location from which I login to our Intranet. Does EA have any built-in tools for capturing performance or measuring speed of response?
NB: Note I am not talking about complex scripts. Even just opening a view and creating a simple link between two elements, etc.
Saeed
Re: EA Sucks?
« Reply #1 on: January 02, 2018, 11:23:13 pm »
Hi Saeed,
Generally speaking the performance of the tool is quite acceptable for most users.
There are however specific things to look at when trying to solve performance issues for EA.
- Database: Oracle is known for having bad performance with EA.
- Network: The software is pretty chatty with the database. When opening a large diagram it might execute a few hundreds of very small queries on the database. If you have a limited network bandwidth that might be the bottleneck. I've heard complaint from people when using their corporate Wifi when the speed was no issue at all when using a wired network.
If upgrading the network is not an option you might want to consider a terminal (citrix, remote desktop,...) solution or look into the cloud solution.
mgraval
Re: EA Sucks?
« Reply #2 on: March 22, 2018, 01:50:37 pm »
I have used the proxy server connection to connect to an EA repository and it worked very good. I was remotely vpn'd from Canada to a DataCenter in Denver with good performance via the proxy server interface. Sorry, could not find the link on the SPARX site for the proxy network config.
Nizam
  • Model Sharing - Simplified
    • Professional Model Collaboration
Re: EA Sucks?
« Reply #3 on: March 22, 2018, 01:54:51 pm »
Saeed
Also connecting via http (using Sparx Cloud service) offers form 40 to 50 percent improvement in performance for WAN  (this service includes WAN optimizer component as well).
Except for bulk XML exports / imports connecting via http is relatively better.
MaXyM
Re: EA Sucks?
« Reply #4 on: March 22, 2018, 08:41:46 pm »
Exactly this. EA if for some reason (or for sake of simplicity of internals) not optimized communication wise. It's not about bandwith about communication medium you use between EA and its storage. EA generates huge amount of requestests, hitting DB even for basic operations like selecting an element on diagram. In such cases indeed Wifi is being penalized a lot.
IMO Sparx should take more care about this.
