Author Topic: Creating deployment  (Read 605 times)
Creating deployment
« on: June 08, 2018, 09:56:20 pm »
On p. 654 of the UML 2.5 specs (fig. 19.7) there's a <<deployment spec>> attached (like an association class) to a deployment connector. How can this be created in EA?
Sunshine
  • Emoji's make you look younger
Re: Creating deployment
« Reply #1 on: June 11, 2018, 02:04:02 pm »
Create a deployment diagram and in the tool box 7th icon down between artifact and Package there it is the Deployment Specification. Drag that onto the diagram. You can then connect it to the deployment connector between the artifact and the node instance.
Was using EA V13.5 in case that matters.
« Reply #2 on: June 11, 2018, 05:07:32 pm »
Ah, sure. 13.5 matters since connectors to connectors is not possible in V<=12.
Cheers, q.
