I held off upgrading from my version 1310 because I wanted to avoid the trap of "where did my menu go?" and did not see much benefit overall. But I'm very eager to upgrade to EA 16 with SQLite repository.
However I just found out that my 1310 has a bug for "Import schema from ODBC" for PostgreSQL (I'm reverse engineering from v. 12.02). The trace log shows ERROR(ERROR) 42702 'column reference "oid" is ambiguous' at this stage:
[53.579]PQsendQuery: 09C69420 'BEGIN;declare "SQL_CUR09FBCC88" cursor with hold for SELECT
n.nspname AS ObjectSchema, --1
c.relname AS ObjectName, --2
CASE
WHEN c.relkind = 'r' THEN 'TABLE'
WHEN c.relkind = 'v' THEN 'VIEW'
WHEN c.relkind = 'S' THEN 'SEQUENCE'
END AS ObjectType, --3
COALESCE(OBJ_DESCRIPTION(c.oid),'') AS Remarks, --4
COALESCE('TABLESPACE=' || t.spcname || ';','') AS Properties --5
FROM
(SELECT *, oid
FROM pg_class
WHERE relkind IN ('r','v')
) c
INNER JOIN
(SELECT *, oid
FROM pg_namespace
WHERE nspname IN ('schema_names') --WHERE nspname NOT IN ('other_schema_names')
) n
ON c.relnamespace = n.oid
LEFT JOIN
pg_tablespace t
ON
c.reltablespace = t.oid
Order By n.nspname, c.relkind, c.relname;fetch 100 in "SQL_CUR09FBCC88"'
[53.822] ok: - 'C' - BEGIN
[53.822] ERROR(ERROR) 42702 'column reference "oid" is ambiguous'
[53.823]PQsendQuery: 09C69420 'ROLLBACK'
I don't have access to EA16 since my registration expired: can anyone confirm if EA16 has no issues reverse engineering from PostgreSQL? Thanks!!!!
