Author Topic: Adding Information Flow Realized later.  (Read 2165 times)
oiwuernnslkdjf
« on: January 21, 2022, 08:34:39 pm »
I have a few Information Flow connectors that are not yet "Realized". According to the manual I should be able do this after adding connector by doing the following:
Right-click on connector | Advanced | Information Flows Realized
Source: https://sparxsystems.com/enterprise_architect_user_guide/15.2/model_domains/informationitemsrealized.html
The "Information Flows Realized" button is missing in my version of EA (v15.2.1588). Is there any other way to Realize an existing Information Flow?
Thanks!
Re: Adding Information Flow Realized later.
« Reply #1 on: January 21, 2022, 08:44:33 pm »
I just tested this (v15.2.1559) on a sequence diagram message, and I saw the option in the context menu as described.
It seems to appear on most types of connectors.
Not on information flow, and not on notelink.
oiwuernnslkdjf
« Reply #2 on: January 21, 2022, 08:56:04 pm »
Thanks Geert for your reply.
I found it now. Its not available on non-realized information flow for me though, only on already realized information flows. I did the following to "convert" an existing non-realized IF to a realized IF:
- ad non-realized information flow to a realized information flow
- add new information flow connector and select "Add Realizing Relationship" in the menu that pops up
- right click this new connector -> Advanced Information Flow Realized -> select the non-realized information flow item
This "removes" the non-realized Information Flow and show it all in the Realized Information flow.
I was not aware of this mechanic of informations flow connectors! Good to have it working now.
« Reply #3 on: January 21, 2022, 09:17:49 pm »
I don't get it.
If you already have an information flow, then you don't need to realize it anymore???
AFAIK this feature is meant to be used to add conveyed eleents to a differnt type of relation such as an asociation or message. In that case you need a realizing information flow.
If you already have a information flow you can simply add the conveyed elements directly.
oiwuernnslkdjf
« Reply #4 on: January 21, 2022, 11:24:30 pm »
Maybe I am using the realized flow incorrectly then. I am working on an existing EA model and there are only realized information flow connectors between blocks. I always interpreted it as "this is what were actually doing" kinda flow.
Here is an image of what I am talking about https://imgur.com/6kn6W4h
Thanks!
« Reply #5 on: January 21, 2022, 11:31:39 pm »
Not necesarrily. I'm not familiar with SysML, so you might be doing things correctly.
KP
« Reply #6 on: January 24, 2022, 09:49:13 am »
There are two connectors between block3 and block4: an Association and the InformationFlow that it realizes.
The Sparx Team
support@sparxsystems.com
