Author Topic: Fragments / frames moving around in sequence diagrams  (Read 4423 times)
thommeread
« on: April 21, 2008, 08:37:24 pm »
I'm going out of my mind here. I'm creating sequence diagrams and including lots of alt, opt, seq, etc. fragments but every time I move anything they all re-organise themselves and move around the page. Also, when I've got the frames in the right position, save, exit and re-open, they've often moved out of position again.
This is like the worst kind of auto-formatting in MS Word. Am I doing something wrong? Is there some way of telling a fragment what contents it should keep within its bounds?
Thanks.
Oliver F.
  • Aren´t we all in the model business ?
    • Karl Storz homepage
Re: Fragments / frames moving around in sequence diagrams
« Reply #1 on: April 21, 2008, 09:54:27 pm »
Errm, yes, EA is a bit oversensitive here.
Sometimes if you have a fragment all items which are at least a few pixels inside will move with it.
If one moves a message down too many pixels on the other hand EA tears apart the timeline. My workaround here is to move the messages only several pixels down, then release, then again a few pixels down, etc.
I believe the algorithm used is a bit too sensitive to changes.
Oliver
thommeread
« Reply #2 on: April 21, 2008, 10:15:42 pm »
Thanks. So: is there a way of showing the layers that are in a diagram? The algorithm must use layering because sometimes moving a frame will also move an unattached note or message above it, but nothing else.
« Last Edit: April 21, 2008, 10:16:14 pm by thommeread »
support@sparxsystems.com
Oliver F.
« Reply #4 on: April 22, 2008, 04:28:21 pm »
Oliver
Ah, well, build 829 is here and in the history I can find this change:
# Improved moving of fragments with messages on a sequence diagram.
That might be worth a look. Guess who is rushing to the download pages now...
Oliver
erobinson
« Reply #5 on: January 31, 2020, 01:06:43 am »
I have recently logged this issue again in V15. Does anyone have a workaround?
« Reply #6 on: January 31, 2020, 01:26:22 am »
You noticed this is a 10 year old thread?
