Author Topic: Default tag values do not work properly  (Read 5319 times)
PJK
  • Transmisi me sursum, Caledoni
« on: December 12, 2017, 12:41:59 am »
Setting a default value for a tagged value type does not in fact record a default value for the tag. It displays the tag as if the value were set, but in fact the value is null, which shows up in RTF reports, etc.
Example - tag "Term Type":
Type=Enum;
Values=Acronym,Event,Location,Resource,Role,Term;
Default=Acronym;
This  will display as "Term Type=Acronym" for a newly created element, but unless the user explicitly uses the drop-down to change the value, the reported value for the element is null. This is worse than useless, as the users are misled into believing that a default value exists.
This bug has been around since at least V11.
Cheers, Phillip
Uffe
Re: Default tag values do not work properly
« Reply #1 on: December 12, 2017, 01:53:41 am »
Ouchie.
Have you reported it?
/Uffe
« Reply #2 on: December 12, 2017, 10:36:50 am »
Just for the record...
I HATE NULLS!
Oh, and the default value can't be left as NULL because NULL is NOT a value!
« Last Edit: December 12, 2017, 10:38:42 am by Paolo F Cantoni »
