Author Topic: Structured Scenarios & context reference  (Read 3580 times)
Ed Barbor
« on: August 24, 2010, 10:56:10 pm »
Hi, I am new here so I hope this issue has not been raised already (I did check but I may have missed it).
I have created a component diagram with some components which are shared so I have created instances of them in multiple places. When writing up a use case using Structured Scenarios I found that although I can select one of the component instances to insert as a context reference within the step the reference loses the component name so, for example, "Instance :OfComponent" becomes "Instance :OfComponent" rather than "Instance :OfComponent" which is what I want. Does anyone have any ideas why that happens and what I can do to work around it?
Secondly, does anyone have any idea if it is possible to insert context references to operations on components into structured scenarios?
Re: Structured Scenarios & context reference
« Reply #1 on: August 25, 2010, 08:47:17 am »
First, it's using only the linked object name, not the classifier name.
Second, no, that hasn't been implemented.
