Author Topic: Diagram -> Save as Image has outline box  (Read 3741 times)
badja
  • Architects Forever !
« on: March 11, 2012, 04:31:56 pm »
When I am doing some whiteboard diagrams and use the Save as Image function in the Diagram menu, the saved image includes a box which outlines the desired image.  Further this box have a title which starts with "class", for example, if my diagram was Overview, then the title is "class Overview".
The term "class" is not appropriate to my whiteboard diagrams.
1. Is there any way of suppressing the title, or the box, in these images, or
2. Is there any way to suppress the term "class" in the title.
Re: Diagram -> Save as Image has outline box
« Reply #1 on: March 11, 2012, 08:16:00 pm »
The term "class" is there because you are printing a Class diagram.  If you change the diagram type (using <Main Menu> |Diagram |Advanced |Change Type), then you'll get a different term there.
badja
« Reply #2 on: March 11, 2012, 09:30:51 pm »
Yes - that works.
Also, I have found in the Tools | Options, under Diagram, I can unclick the Diagram Frames - On Saved Images.  This removes the frame altogether, which I think is a better option in my case.
