Author Topic: Mixed ANSI C++, C++/CLI project  (Read 3740 times)
onsager
« on: March 13, 2012, 02:06:49 am »
@list
I have such a beast and I'm seemingly unable to import some of its parts properly from source files in 'Code Engineering'. Problem is, the only way to tweak the exact C++ source type seems to be a global/model based one.
Is it possible to do such things on a package/diagram/file-by-file base? Currently, I'm getting parse errors in some C++/CLI classes mostly caused by the  '^' operator, essentially breaking the step.
Re: Mixed ANSI C++, C++/CLI project
« Reply #1 on: March 13, 2012, 08:08:18 am »
Unless something has changed since I last looked at it, there is one C++ import that serves all C++ dialects. If that's the case, it's just that EA doesn't know about the particular syntax you have used. Which means you would have to report a bug to sparx systems directly.
« Last Edit: March 13, 2012, 08:08:44 am by simonm »
onsager
« Reply #2 on: March 13, 2012, 07:30:53 pm »
Meanwhile, I can acknowledge this. For the sake of completeness:
Replacing declarations as in
XYZ^ xyz_0, ^xyz_1;
by
XYZ^ xyz_0;
XYZ^ xyz_1;
will reconcile the EA parser.
