Author Topic: Pinning ends & Line Style compete  (Read 3556 times)
« on: March 21, 2012, 01:43:20 pm »
If you pin either or both ends of a line with a particular line style (say Tree Style Vertical), the line style changes to Custom Line.
If you manually move the line end before pinning, EA will honour the line style.  EA will also attempt to honour the new (unpinned) end point as the vertex is moved around the screen.
I see no reason for pinning the end causing the Line Style to change.
Further, changing the line-style for an arc with pinned ends will reset the end-pinning.
The current functionality causes users to manually realign the arc when the vertices are moved around!
Reported
