Author Topic: EA jet database error  (Read 5064 times)
korsbecker
« on: March 22, 2012, 06:45:18 pm »
Hi All
How do I get rid of this message:
http://imageshack.us/f/69/eaerror.jpg/
"the microsoft database engine stopped the process because you and another user are attempting to change the same data at the same time"
There is only one user using this *.eap file, but the users EA crashed just before this error occurred!
regards
henrik :-)
Re: EA jet database error
« Reply #1 on: March 22, 2012, 10:56:05 pm »
I guess simply by switching to a *real* database.
korsbecker
« Reply #2 on: March 22, 2012, 11:07:49 pm »
There is no "database" involved apart from what might be used internally by EA!!!
henrik
« Reply #3 on: March 22, 2012, 11:29:41 pm »
That's what I'm saying. Instead of using a toy-DB (which EAP aka. MS Access definitely is) switch to something real.
korsbecker
« Reply #4 on: March 23, 2012, 04:39:45 pm »
Ok I wasn't aware that the EAP is a ms jet db.. sorry but it still doesn't solve my current problem that I can't access one of my diagrams!
regards
henrik :-)
« Reply #5 on: March 26, 2012, 10:11:13 pm »
Henrik,
You can either try the EA repair function, or use MS-Access to try and repair the .eap file.
That might just solve the issue.
« Reply #6 on: March 26, 2012, 10:17:15 pm »
If all that does not help: export the model as XMI and create it from scratch. You might then re-transfer selected packages. Or try a model transfer.
