Author Topic: Import Source Directory has dissappeared 9.3  (Read 4362 times)
hermione
« on: April 05, 2012, 09:57:53 am »
I've recently upgraded my Corp edition from 9.2 to 9.3.
Import Source Directory menu item has dissappeared under version 9.3. The help text says it should be under Tools menu.
cheers
« Last Edit: April 05, 2012, 09:58:42 am by hermione »
Aaron B
Re: Import Source Directory has dissappeared 9.3
« Reply #1 on: April 05, 2012, 10:57:08 am »
See: View | Workspaces and Commands > Commands
See also:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1333454600/2#2
hermione
« Reply #2 on: April 05, 2012, 11:01:52 am »
Awesone thanks Aron  :)
g.makulik
« Reply #3 on: April 05, 2012, 11:03:54 am »
I've seen this answer several times now. How TF can it happen that in some cases (of upgrading??) menu entries disappear, without having been edited (guess so) in the new 'Workspaces and Commands' section??
Just my 0.02$
Günther
« Last Edit: April 05, 2012, 11:04:56 am by g.makulik »
« Reply #4 on: April 12, 2012, 12:57:23 pm »
Günther, when EA 9.3 is opened for the first time, it shows the wizard to the user. They have apparently selected a command set that doesn't include the commands that they are using.
The question is whether the command set selected should contain that command (which would be our error) or if the user selected an inappropriate set (we probably need to provide more information about what the command set does). In this case that can't be determined because we don't know which command set they selected.
« Last Edit: April 12, 2012, 12:58:27 pm by simonm »
« Reply #5 on: April 12, 2012, 08:12:51 pm »
Right after falling in that trap after upgrading I posted this as being harmful. You must not offer such options during an upgrade. Just leave it to users to remove functionality AFTER the upgrade is through and they a comfortable with the new options.
