Author Topic: Source shape also breaks Target shape  (Read 3528 times)
« on: April 18, 2012, 11:52:37 am »
If a source shape is defined for an arc but a target shape is not defined, the target end is also suppressed.  For example, suppose I have a dependency for which i wish to redefine only the source shape I define a source shape only.  The arrowhead at the target end also disappears.  It should not.  If the main shape is not defined, then EA (correctly) draws the main line of the arc in the correct form.
For arcs, if a particular shape is NOT defined in the ShapeScript, EA should draw the native shape corresponding to the undefined shape.
Reported
[size=0]©2012 Paolo Cantoni, Semantica[/size]
