Author Topic: 9.3 931 - Glossary Problem?  (Read 5788 times)
OneCent
« on: April 23, 2012, 06:39:46 pm »
Hi
I try to edit my Glossary in 9.3 and i can't edit a old entry or add a new one. The buttons new, save and delete are allways disabled.
Any hint to solfe that problem?
Cheers, OneCent
AndyBo
Re: 9.3 931 - Glossary Problem?
« Reply #1 on: April 24, 2012, 02:36:31 am »
I had a similar problem
It turned out to be a permissions problem with the version control system
The permissions had to be added separately to the model
« Last Edit: April 24, 2012, 02:42:05 am by AndyBo »
« Reply #2 on: April 24, 2012, 02:53:23 am »
Check your EA security settings.
« Last Edit: April 24, 2012, 02:54:01 am by qwerty »
OneCent
« Reply #3 on: April 24, 2012, 08:42:24 pm »
Thanks a lot!
JohnRGladstone
  • I don't make predictions... and I never will
« Reply #4 on: April 27, 2012, 05:06:35 pm »
Don't suppose you have any idea if it is possible to import a pre-existing list of terms from a Word document into EA?
I've got a massive list of terms to capture and don't fancy typing them all in one at a time
philchudley
« Reply #5 on: April 27, 2012, 06:37:12 pm »
Hi John
Not "out-of-the-box", however the following may work.
1) Extract the glossary into Excel and format accordingly
2) Export to csv
3) Write a bit of code that reads the csv and creates a series of SQL Insert statements.
4) Execute the SQL Insert statements against the underlying EA repository using Access or your chosen DBMS (insert sql statements cannot be executed within the EA workspace)
The repository table details you will need are
Table name - [highlight]t_glossary[/highlight]
Table attribute - [highlight]Term[/highlight]
Table attribute - [highlight]Meaning[/highlight]
Table attribute - [highlight]GlossaryID[/highlight]
The last field is incremental and should start from 1 for a new glossary or continue from the last number for a glossary with existing entries
Something like the following
INSERT INTO t_glossary
(Term, Type, GlossaryID)
VALUES
(value-1, value-2, value-3)
Cheers
Phil
Models are great!
