Author Topic: EA Copy / Paste Issue  (Read 11428 times)
AdrianHo
« on: April 27, 2012, 04:33:55 pm »
I'm having issues copying diagram elements and pasting into other programs (Paint, MS Office, etc)
For diagrams with more elements, a number of the elements show up as blank rectangles (I have them all set as stereotyped classes with stereotype level appearence overide)
I've tried changing Tools > Options > Diagram > Image Memory Limit to 512mb (max) and it makes no difference.
I don't want to resort to just using Print-Screen as it results in lost functionality (pasting into MS Office then allows you to edit / delete / add to the diagram)
Any insight would be much appreciated  :)
AdrianHo
Re: EA Copy / Paste Issue
« Reply #1 on: April 30, 2012, 09:28:27 am »
Update... it seems like number of elements is not a factor, but rather any items below a certain point vertically will not show correctly!
I still need to find a resolution to this because I consistently have diagrams this size or bigger.
« Last Edit: April 30, 2012, 09:36:55 am by AdrianHo »
« Reply #2 on: April 30, 2012, 08:09:09 pm »
Sounds strange. You should contact Sparx support!
« Reply #3 on: May 01, 2012, 08:28:07 am »
I've seen it before.
As far as we could tell, it was a limitation of the metafile format that it couldn't handle embedded images after a certain point was reached.
« Last Edit: May 01, 2012, 08:28:41 am by simonm »
