Author Topic: Exporting as XPDL format for use in ALM 11  (Read 5493 times)
David01
« on: May 03, 2012, 08:08:31 pm »
We need a confirmed answer from you w.r.t. the below. We use Quality Centre (ALM11) and it can import models. One of our clients uses your product. Do you have suggestions?
ALM supports 2 Notations:
1. BPMN v 1.1 Business Process Modeling  Notation.
2. EPC v 7.1 (Event-Driven Process Chain) Developed within the ARIS framework. It appears that ARIS of Software AG and VISIO of MS (among others) use this notation.
Models should be exported (for Import to QC) from the modeling tools in one of 2 formats:
1. XPDL 2.0 XML Process definition Language - is a format standardized by the Workflow Management Coalition (WfMC) to interchange business process definitions between different workflow products
2. ARIS XML file formats
RoyC
  • Read The Help!
Re: Exporting as XPDL format for use in ALM 11
« Reply #1 on: May 04, 2012, 10:40:53 am »
Hello David
This is a user forum, and you are primarily addressing other users like yourself.
To get the information you require, please contact Sparx Support on [email protected], or Sparx Sales on [email protected].
Best Regards, Roy
« Reply #2 on: May 04, 2012, 11:37:21 am »
I wouldn't expect to get either of those formats out of EA any time soon.
However, you could try exporting to BPMN 2.0 and converting using http://www.businessprocessincubator.com/do/convert/convert-a-webmodeler-file-to-xpdl-2-2.html
It's a commercial service (and not affiliated in any way with Sparx Systems), but it might be worth a try.
