Author Topic: Version 3.60 - Build 646 Released  (Read 22929 times)
sparks
« on: October 05, 2003, 11:36:54 pm »
Changes and Fixes in Version 3.60 - build 646
Added additional highlight for context element in diagrams - when selected has hatch border.
     . Context element is one used for alignment operations not using mouse
     . Can be turned off on the Diagram/Behavior page of Options dialog
Modified Project Browser to improve context menu behavior and added warning before reloading model when changes by other user detected
Changed Add-In template file from DLL format to Type Library format for improved language independence. See help file for details on writing Add-Ins using Add-In Template Type Library
Added option to Tools/Option dialog to not expand drop target packages when doing a node trasnfer in project browser
Fixed VBNet Comment parser behavior - XMLDoc, JavaDoc & standard comment
Fixed VB & VBNet processFunction arguments (multiple lines)
Various Code Generation Template updates
Modified CreateProperty dialog behavior on Attributes dialog (to improve property creation & modification)
Modified diagram alignment behavior to use last selected element in group selection when aligning via main menu
Fixed issue with conditions on Collaboration messages caused when re-sequencing the collaboration messages
Corrected possible problem when printing or saving images with 'Display Watermark' ticked, but not text set to display
Modified some string resources to correct displayed tooltips
Modified RTF Report dialog to allow creation of new Template when started from <<Model Document>> class
Limited Extended Properties on Operations for Tables to Indexes and Foreign Keys
Improved Boundary, Text and Note behavior to retain font and color settings when pasting as new copy
Modified RTF format of Requirements/Linked Requirements to make them match
Modified RTF format of Requirements/Linked Requirements to hide status and advanced information when "Object Detail" unchecked
Corrected problem with Code Generation toolbar - which could cause exception when showing context menu under certain circumstances (affects XP and Win3K only)
Modified .EAP file repair functions to be grayed out when no EAP file loaded.
Modified XMI import/export to move connector end stereotypes from the attribute to tagged value level. Issue with DTD
Extended behavior of locking on View and Project roots to allow deletion of View or root when "Require User Lock to Edit" is the security mode
Fixed option for auto-generating interface methods
Updated C# operation templates: removed invalid modifiers on interface operations
Updated C++ FileImpl template: uses %fileNameImpl% instead of %fileName% in comment section
Added ability to bookmark (red triangle) alternate images and stereotyped metafiles
Fixed issue with automation interface that could prevent "CreateObject" working in some instances
