Author Topic: Association Class and Composite Diagram  (Read 5862 times)
Uffe
« on: May 31, 2012, 05:57:01 pm »
Hi!
I've noticed some weird behavior concerning association classes: it seems a class can be either an association class, or be a composite element with its own diagram.
First I create an association class between two other classes.
If I then make the class composite, it is no longer displayed as an association class in the hover tooltip or properties dialog. It retains the reference to the association connector.
If I remove the class from the diagram, then right-click the connector, the "Find Association Class" and "Show Association Class" options are still available.
But if I pick "Show Association Class", EA removes the link between the class and the connector.
If I then place the class in the diagram again an right-click it, I can select Advanced - Association Class and pick the association.
This makes the class non-composite. Its contained diagram is still there.
I've noticed that the NType column in the t_object table switches between 17 for an association class and 8 for a composite one.
Does anyone know of a reason why association classes should not be allowed to be composite?
Or is this simply a bug?
Cheers,
/Uffe
Re: Association Class and Composite Diagram
« Reply #1 on: June 05, 2012, 10:19:47 am »
Hi Uffe,
There are a number of EAUI issues with AssociationClasses.
Report the bug...
Concistency, konsistency, consistensy! TMUffe - after Paolo
Uffe
« Reply #2 on: June 05, 2012, 03:27:39 pm »
Yes, thanks. I've reported it and had it confirmed as a will-be-fixed. Issue 12062975.
Cheers,
/Uffe
