Author Topic: Cannot connect to an EA MySQL repository using ODC  (Read 5672 times)
Wivel
« on: August 03, 2012, 06:57:03 am »
Hi
I am planning on using MySQL for my EA repositories so I have:
- Downloaded and installed the latest MySQL (5.5.x)
- Created a new schema using the MySQL interface
- Downloaded the initializing script for InnoDB and executed it successfully
- Created a User DNS pointing to the created schema and checked the options needed as documented by Sparx
- Testing the connection works just fine.
Now I want to connect to the newly created database from EA and here is where the fun starts. When I try to connect I get errors as:
- Unspecified Error
- Catalog information cannot be retrieved
What am I doing wrong?
I am using EA 9.3 latest, greatest on Windows 7 64 bit.
Henrik
hd
Re: Cannot connect to an EA MySQL repository using
« Reply #1 on: August 03, 2012, 07:45:26 am »
Wivel
« Reply #2 on: August 03, 2012, 08:49:30 am »
Solved it!! I didn't create the ODBC driver using tht 32bit ODBC tool. Once I did that instead of using the standard 64bits ODBC tool, it worked!
