Author Topic: Error on startup  (Read 5395 times)
OpenIT Solutions
Error on startup
« on: August 04, 2012, 12:50:33 am »
I have a user that gets the error message 'failed to create empty document' when ever they start Sparx. It then closes down.
Anyone come across this error ? Any suggestions on how to solve ?
Jon.
Re: Error on startup
« Reply #1 on: August 04, 2012, 02:33:18 am »
No idea. Can they open an EAP via dbl-click?
g.makulik
« Reply #2 on: August 04, 2012, 03:02:50 am »
Sounds like the EA DB schema is missing?! What's your customers setup? Do they use a RDBMS repository or local.eap files?
Just my 0.02$
Günther
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: August 04, 2012, 06:29:02 pm »
If you use Windows XP (or earlier OS), restarting OS may solve the issue. The message is shown when OS system resource is not enough.
t-kouno
« Reply #4 on: August 05, 2012, 03:35:18 pm »
Yes,  It is predominantly an OS problem with XP.  If you have too many windows open, XP will return this with EA.
I used to get it most when trying to open multiple copies of EA simultaneously.
EA 9+ helps the problem by reducing the load EA puts on the OS, but ultimately, it's outside EA's control on XP.
If you want to avoid restarting, close other tasks.
« Last Edit: August 05, 2012, 03:37:16 pm by PaoloFCantoni »
« Reply #5 on: August 06, 2012, 04:15:13 pm »
Specifically, check for opened GDI objects on your task manager.
I think there's a global limit of about 10.000 of those.
If you have a lot of GDI intense programs running (think Outlook, IE, EA) then you run out of them.
