Author Topic: Local Path  (Read 3273 times)
dmayworm
Local Path
« on: August 07, 2006, 12:05:07 pm »
Hi!
I´m having trouble in my project using the Enterprise Architect, basicaly in the paths to work with many people in my company....
the following  thing is: I´ve loaded the file with the model and then I set the path(settings->local paths) where the code is located, but when I syncronize nothing happens... ???
what can it be?
Re: Local Path
« Reply #1 on: August 07, 2006, 03:24:56 pm »
Not sure what the problem could be at the moment.  Is the language of the local path set correctly?
If you select a class can the source code editor find the right file?
Could you give an example of the following for a class that synchronise doesn't work for?
Absolute path to the file:
Path in the EA properties:
Local Path Set up:
