Author Topic: Version Control missing after 9.3.934 upgrade  (Read 3692 times)
schurms
« on: August 22, 2012, 10:59:11 am »
Hi. Just upgraded from 9.1 to 9.3.934 2 days ago (before the latest software.)  At the time I verified all version control options were there.  Right click the package and check out - worked fine.  Opened software today and all packages are still marked as under version control, but there is now no option to check out the package when I right click on the package.
So I can not check out any packages to work on them.
There is also no option under Project to configure Version control.
Any thoughts how I can reenable it as the path still points to the local TFS package.
There have been no changes to TFS as have 7 other colleagues still on 9.1 successfully accessing the version controlled package.  Seems to just be mine with 9.3.934 since upgrading that version control is now not available.
RoyC
  • Read The Help!
Re: Version Control missing after 9.3.934 upgrade
« Reply #1 on: August 22, 2012, 11:40:46 am »
Try selecting the View | Workspaces and Commands menu option, and the Commands tab on the dialog. Make sure that Complete is selected, and all checkboxes in the right-hand panel (especially, in this case, Version Control).
For more information, see the Help (Getting Started > User Interface Guide > Customization > Manage Workspace Layout).
Post again if this does not help you.
Best Regards, Roy
schurms
« Reply #2 on: August 22, 2012, 01:36:08 pm »
Roy.  Many thanks works a treat. ...Cheers...Sean
