Author Topic: Timestamp in diagram notes at 00:00:00  (Read 3919 times)
Steve 5519
« on: July 30, 2012, 05:41:03 pm »
Hi
I'm new to EA and I am having a problem with the "Created " and "Updated" timestamps. When added to the diagram they are correct but when the diagram is saved then the timestamps read. 00:00:00. What am I missing.
I'm using EA version 7.5.850.
Exart
Re: Timestamp in diagram notes at 00:00:00
« Reply #1 on: August 22, 2012, 09:46:55 pm »
Are you using MySQL database?
I'm asking about it because there is a little bug in MySQL Schema.
There is:
DROP TABLE IF EXISTS `t_diagram`;
CREATE TABLE `t_diagram` (
  `CreatedDate` date DEFAULT NULL,
  `ModifiedDate` date DEFAULT NULL,
It should be:
  `CreatedDate` datetime DEFAULT NULL,
  `ModifiedDate` datetime DEFAULT NULL,
You can modify schema as below:
ALTER TABLE `t_diagram` CHANGE `CreatedDate` `CreatedDate` DATETIME NULL DEFAULT NULL;
ALTER TABLE `t_diagram` CHANGE `ModifiedDate` `ModifiedDate`  DATETIME NULL DEFAULT NULL;
« Reply #2 on: August 22, 2012, 10:10:54 pm »
I just check in our model (SQL Server) and we don't seem to have an issue with that.
All timestamps are filled in correctly (up to the seconds)
Steve 5519
« Reply #3 on: August 29, 2012, 04:06:15 am »
 My thanks to Exart. The problem is fixed.
