Author Topic: DB2 error while reverse engineering  (Read 3603 times)
gmills65
« on: September 12, 2012, 03:10:47 am »
I'm not new to EA but I am with respects to DB2. After I select import on the Import DB schema from ODBC source dialog I'm getting a Database cannot be opened warning, I press ok and I get a Table list cannot be retrieved warning.
I assume I can connect to the database properly because as I select the ellipsis I can select the ODBC connection. The problem occurs when I select Import. Also I can connect when testing the ODBC connection through the Windows 7 Control panel.
A side note, I select Yes on the dialog immediately after selecting import.
The question states "Select version of DB2 to import...
Press Yes to import from DB2 on Windows or Linux, No to import from other versions fo DB2, Cancel to abort."
What could be the issue?
