Author Topic: Can´t create BPMN model  (Read 3656 times)
Gerardo
« on: October 02, 2012, 07:55:33 am »
Hello, I can´t create BPMN model, I´m using: EA version 9.3 running on Windows 7, 64bit. When I try to create, this it´s what happened
http://imageshack.us/photo/my-images/29/errorea.png/
Any Idea ?
Thanks in advance
Re: Can´t create BPMN model
« Reply #1 on: October 02, 2012, 09:21:47 am »
1. There isn't enough information in that screen shot to know what is the problem. Please contact Sparx Support and they should be able to help you.
2. That isn't a BPMN model that you're trying to create.
Gerardo
« Reply #2 on: October 02, 2012, 09:38:02 am »
Hi KP, thanks for answer, unfortunaly that is all the information there I have.
About the point 2. Why ? if: "Business Process Modeling Notation (BPMN)"
Any way i will try to get contact with the support.
Thanks again.
« Reply #3 on: October 02, 2012, 09:52:32 am »
The package you are trying to import is named "Business Process" but it has nothing to do with BPMN - it is a different, older notation. Try importing (select a package in the project browser and press Ctrl+Alt+I) the file C:\Program Files (x86)\Sparx Systems\EA\ModelPatterns\bpm.xml and you will see what I mean (and if you cannot import that file, that will be a good clue as to the cause of the previous error message).
« Last Edit: October 02, 2012, 09:53:09 am by KP »
Gerardo
« Reply #4 on: October 02, 2012, 10:05:16 pm »
Hello again KP, thanks for answer, I tell you, when i try to import the model "C:\Program Files (x86)\Sparx Systems\EA\ModelPatterns\bpm.xml" I have got the same error, it´s the same problem.
So when I try to import another model, for example clm.xml it´s works fine.
This is a bug?
