Author Topic: MSSQLScriptUpdatePatch_2005-8.xml on MS-SQL server  (Read 3615 times)
Larsern
« on: October 08, 2012, 07:12:56 pm »
Hi there!
Is the script mentioned above only targeting the 2005 server of MS-SQL or do I have to run the script on a 2008 R2 server?
Thanks in advance.
Lars F.
hd
Re: MSSQLScriptUpdatePatch_2005-8.xml on MS-SQL se
« Reply #1 on: October 09, 2012, 07:47:14 am »
http://www.sparxsystems.com/resources/corporate/index.html#sql_scripts
See paragraph above download links...
Also listed with each DBMS are update scripts, designed to improve performance on model repositories which were created using scripts downloaded prior to February 10, 2010. The update scripts add indexes to the database schema.
And the list of SQL Server versions...
SQL Server 2000/2005/2008, Express 2005/2008
