Author Topic: Qualifier layout issue on Aggregations  (Read 3672 times)
Jack @ YTGI
« on: October 14, 2012, 12:36:43 am »
In producing a class diagram, when adding qualifiers to the aggregation, the text will not wrap. I noticed that sometimes if that happens, you can manage to resize the box to force the wrap. I've run into this issue where I can't. It makes the drawing difficult to work with. Any suggestion on how I can force the wrap?
Notice how three of the qualifiers are just fine, but the one on the bottom left will not wrap. I even deleted and recreated the aggregation.
Jack Yasgar
Yasgar Technology Group
Re: Qualifier layout issue on Aggregations
« Reply #1 on: October 15, 2012, 05:02:52 am »
AFAIK this is something you always have to do manually (except you're an API wizard). It's always fiddly to resize any kind of label. The best I found is to drag if out of the way, resize it and put it back.
Jack @ YTGI
« Reply #2 on: October 19, 2012, 10:05:42 pm »
Thanks QWERTY, I had tried that already, it will not let me grab the corner on this 1 out of the 4. I even zoomed the screen to maximum to make sure it was not just a mouse positioning issue.
Jack Yasgar
« Reply #3 on: October 20, 2012, 03:33:01 am »
Probably you should send a bug report (link at bottom of this page) to Sparx support.
« Reply #4 on: October 22, 2012, 08:36:34 am »
There used to be a bug with grabbing the corners of labels next to aggregation diamonds: the grab point was the length of the diamond away from where it should have been. I don't know when it was fixed, but it certainly works correctly in the latest version.
